Swize Posted June 27, 2005 Report Share Posted June 27, 2005 (edited) Speaking to dave@tartybikes we are not quite sure if snail cams will work on an onza t-pro 04 with an onza tmaster hub, there echo cnc snail cams same as on echo hubs ? Any one run this ? Last thing are snail cam's any good or would people just reccomend sticking with gusset chain tugs ? Cheers Sam Edited June 27, 2005 by samthebiker Quote Link to comment Share on other sites More sharing options...
hulltrialser Posted June 27, 2005 Report Share Posted June 27, 2005 i have a t-master hub and it has those little metal pind on so i ground them off so i am able to run snailcams. Hope this helps. Ben Quote Link to comment Share on other sites More sharing options...
Caleb Posted June 27, 2005 Report Share Posted June 27, 2005 I dont think you can get snail cams on the t-pro range to fit as the dropoout are too long unlike the echo team for example where they will. Your bests bet are some gusset etc tensioners and they wont slip eithere. Tartybikes have em i believe :( Quote Link to comment Share on other sites More sharing options...
JT! Posted June 27, 2005 Report Share Posted June 27, 2005 Well, the t-pro have the hole for the bolt to go in, but i'm not sure if it would work. Logicaly they should be better. :( Quote Link to comment Share on other sites More sharing options...
