trialsguru Posted June 21, 2005 Report Share Posted June 21, 2005 what rear hub can i run on a 20" revell, it needs to have a disc mount cheers! Quote Link to comment Share on other sites More sharing options...
Tartridge Posted June 21, 2005 Report Share Posted June 21, 2005 http://www.trials-nation.com/?page=image_p...5p3c987a86d.jpg :P Quote Link to comment Share on other sites More sharing options...
trialsguru Posted June 21, 2005 Author Report Share Posted June 21, 2005 needs to be threaded for fixed wheel sorry Quote Link to comment Share on other sites More sharing options...
Si-man Posted June 21, 2005 Report Share Posted June 21, 2005 The old megamo one. Im sure caleb on here still has one. Have a chat with him :P Quote Link to comment Share on other sites More sharing options...
Caleb Posted June 21, 2005 Report Share Posted June 21, 2005 Lol im sure it took Phil like 4 months to get that hub and then when he finally did his megamowent or he had got his python then swapped it for a king bmx :P" . Certainly a beautiful hub. I do have a bike gas hub on the traditional rim aye but im afraid the original axle got a bolt stuck in it so im using one that doesnt seem to work. Ill probably sell up though now as my megamos cracked again and cant be doing with the fiddling for an unecassary bike, and need money lol :D" Quote Link to comment Share on other sites More sharing options...
trialsguru Posted June 21, 2005 Author Report Share Posted June 21, 2005 how much for it? is there anyway of fixing the axle? Quote Link to comment Share on other sites More sharing options...
loffa Posted June 21, 2005 Report Share Posted June 21, 2005 You could get a Monty disc hub. Quote Link to comment Share on other sites More sharing options...
trialsguru Posted June 21, 2005 Author Report Share Posted June 21, 2005 do monty do a rear disc hub? where? price please? tah Quote Link to comment Share on other sites More sharing options...
tom e Posted June 21, 2005 Report Share Posted June 21, 2005 do monty do a rear disc hub? where? price please? tah ← the 05 montys have a disc mount, so i presume they do, you can enquire about them at www.cleanbikes.co.uk Quote Link to comment Share on other sites More sharing options...
JT! Posted June 22, 2005 Report Share Posted June 22, 2005 (edited) Most hubs come with a smaller thred for a screw on disk mount (can also be used for 14t freewheels). Like the old t-mag hubs,a nd the try-all hub's etc etc. Just get one of them, and a screw on disk tab. I'm quite sure the majority of fixed hubs come with that smaller thredded bit on one side. Jobs a good'en. Edited June 22, 2005 by JT! Quote Link to comment Share on other sites More sharing options...
Will Arnold Posted June 22, 2005 Report Share Posted June 22, 2005 Most hubs come with a smaller thred for a screw on disk mount (can also be used for 14t freewheels). Like the old t-mag hubs,a nd the try-all hub's etc etc. Just get one of them, and a screw on disk tab. I'm quite sure the majority of fixed hubs come with that smaller thredded bit on one side. Jobs a good'en. ← job isnt a fooking good un! the disk tab will just screw off :) and, no, loctite wont work :D Quote Link to comment Share on other sites More sharing options...
sjpearless Posted June 22, 2005 Report Share Posted June 22, 2005 (edited) thats why they coem with a lock ring. like the dmr singlespeed hub does that and has a lock ring to prevent it from coming off. thechink Edited June 22, 2005 by thechink Quote Link to comment Share on other sites More sharing options...
Will Arnold Posted June 22, 2005 Report Share Posted June 22, 2005 thats why they coem with a lock ring. like the dmr singlespeed hub does that and has a lock ring to prevent it from coming off. thechink ← but he didnt mention the dmr singlespeed hub :) Quote Link to comment Share on other sites More sharing options...
sjpearless Posted June 22, 2005 Report Share Posted June 22, 2005 yeah thats why i put LIKE the dmr. LIKE simon Quote Link to comment Share on other sites More sharing options...
JT! Posted June 22, 2005 Report Share Posted June 22, 2005 job isnt a fooking good un! the disk tab will just screw off :blink: and, no, loctite wont work (Y) ← Why won't locktite work? It really does hold stuff rock hard. Quote Link to comment Share on other sites More sharing options...
Will Arnold Posted June 22, 2005 Report Share Posted June 22, 2005 Why won't locktite work? It really does hold stuff rock hard. ← loctite doesent completely lock a thread, you can still undo a screw with it on etc.. so loctite wont hold imo, but be my guest to prove me wrong :blink: ta Quote Link to comment Share on other sites More sharing options...
JT! Posted June 22, 2005 Report Share Posted June 22, 2005 loctite doesent completely lock a thread, you can still undo a screw with it on etc.. ← I'd dissagree, the one on my front wont budge, i'v tryed. but maby there could be much more forse on the rear. :blink: Quote Link to comment Share on other sites More sharing options...
sjpearless Posted June 22, 2005 Report Share Posted June 22, 2005 can you glue it then drill through it and lock it up like they do with bolts on engines. thechink Quote Link to comment Share on other sites More sharing options...
Will Arnold Posted June 22, 2005 Report Share Posted June 22, 2005 can you glue it then drill through it and lock it up like they do with bolts on engines. thechink ← if you mean drill right through it then wack a pin through, it wouldnt work, but maybe drill through only just past the threads, tap it, then wach a grub screw in (Y) or just use araldite or similar :blink:" Quote Link to comment Share on other sites More sharing options...
spunkey_monkey_boy Posted June 23, 2005 Report Share Posted June 23, 2005 or just get a hub with the disk mounts built into it and don't f**k arse around bodging things... speak to cleanbikes about the monty hubs... Quote Link to comment Share on other sites More sharing options...
Will Arnold Posted June 23, 2005 Report Share Posted June 23, 2005 i was going to enquire about a profile 12t cogged rear mod disk hub, but never got around to it... also, if you have a profile already, you might be able to put all your unternals into an mtb disk hub shell, just a thought, something that tarty and i discussed... anyways, ta Will Quote Link to comment Share on other sites More sharing options...
Si-man Posted June 23, 2005 Report Share Posted June 23, 2005 just get Calebs if he still wants to get rid of it and take it to an engineers place and get a new axle made up, simple :blink: Or if you can use a lathe, do it yourelf Quote Link to comment Share on other sites More sharing options...
011001000110010101110010 Posted June 23, 2005 Report Share Posted June 23, 2005 http://www.trials-nation.com/?page=image_p...5p3c987a86d.jpg (Y) ← 'Tis my wheel now. I had an ECHO hub with a disc mount ages ago. I'm sure there are a few still around. Quote Link to comment Share on other sites More sharing options...
Will Arnold Posted June 24, 2005 Report Share Posted June 24, 2005 http://www.bikedock.com/posit/shop/manfstk.php?manf=MONTY half way down that page you will find the monty disk hub ;) nearly 70 quid aint too bad either i suppose... Quote Link to comment Share on other sites More sharing options...
