Evo Mounts With 4 Bolt
Mr Motivator
Yeah, you can bodge it, but it is well worth paything for the mounts ( get them 2nd hand if you must). It really makes fitting the brake much more simpler. :lol:
My bike has that bodge on it right now (I've got some 4 bolt mounts but they put the slave cylinders to far out so I need new pads and I'm skint.) But you wont be able to use your boosters because the spacing is wider, although you can re drill it in the right place. :P
the main problem with the evo mounts is vertical adjustment, as you are using the top hole from the evo mounts, you obviously cant move them up or down, and have to reply on angling the calliper, which will of course give uneven pad wear if you dont set them up straight....
as a temp though, tehy work just fine!
and i can be bothered at 7:20 am?
im not thick or lazy (most of the time anyways) jus at 7:20 AM then its a bit early to be on computers lol
geek lol
jokes
DAN
Yeah, sorry it came across wrong. I was just putting it there for people refer to, and for future refernce. What the hell you doing awake at 7:20?
