rich4130 Posted June 10, 2005 Report Share Posted June 10, 2005 Hey, by that I mean, when you 180, stay on the back wheel and kinda roll into fakie. In TM1 Tim Pratt section, 1.30ish, and Steve-as vid, about the same time.. I've been trying these this evening, and i'm getting a bit confused, i assume you need to go straight into fakie? I'm struggling to get them, silly I know, any tips for them? I take it you stay off the brake? cheers, im confued hehe rich Quote Link to comment Share on other sites More sharing options...
Dr. Nick Riviera Posted June 10, 2005 Report Share Posted June 10, 2005 if i remember when i did one by fluke i was using the tension of the chain against the hubs engagement to keep me up rather than my balance , although i know nothing else about the trick and it happened purely by accident Quote Link to comment Share on other sites More sharing options...
Sameer Posted June 10, 2005 Report Share Posted June 10, 2005 You need to be able to pull snappy 180's out of the bag first... not one of these sloppy trials-rider 180's. You also need to know how to roll in fakie on both wheels, preferably at a fair speed so you're used to the motion. Once you got them down to a T practise staying on the backwheel after the 180, as opposed to flopping it all down and rolling fakie on both wheels. Then it's just a case of 2 + 2. Snap a 180 and stay on the rear. Like the guy said above, you could always use the chain tension or whatever it is to keep upright, but you should eventually learn to do it without. Because of the momentum from the original 180, you'll be sort of spinning out of the fakie as well, so you needn't worry about turning or anything, it'll just happen for you. And yea, no brakes. All comes down to practise at the end of the day, just like every other thing. Quote Link to comment Share on other sites More sharing options...
