tipsy Jock Posted June 10, 2005 Report Share Posted June 10, 2005 Heya doods, I've recently just been having more fun linking stuff together than actually doing say a big gap or a nice up. This is mostly due to being bored and only having a few curbs outside my house lol. The curb vids were a great inspiration except that i struggle with most of the more complex moves in them :wub: The main thing i want to learn is static 360's (not hopping but one big spin from two wheels back to two wheels) I figured then i can use that skill to spin lesser amounts etc. I can pedal hop 180 from two wheels at the mo, and 180 off stuff if that helps (Y) Any help much appreciated!! Quote Link to comment Share on other sites More sharing options...
Dr. Nick Riviera Posted June 10, 2005 Report Share Posted June 10, 2005 higher tyre pressure , and once youve started the rotation try and lead with your shoulders in the same way as when 180'ing and your body and the bike should follow Quote Link to comment Share on other sites More sharing options...
tipsy Jock Posted June 10, 2005 Author Report Share Posted June 10, 2005 higher tyre pressure , and once youve started the rotation try and lead with your shoulders in the same way as when 180'ing and your body and the bike should follow ← coolio, shall pump me tyre up and try it (Y) Pete Quote Link to comment Share on other sites More sharing options...
Mr Motivator Posted June 10, 2005 Report Share Posted June 10, 2005 Dont worry about tyre pressures, just preload, lean over the bars, throw your body round and turn your head and look were you want to go and your body shall follow. Then when your vertical, click your hips and spin out the rest whilst lowwering the front. (Y) Quote Link to comment Share on other sites More sharing options...
tipsy Jock Posted June 10, 2005 Author Report Share Posted June 10, 2005 Dont worry about tyre pressures, just preload, lean over the bars, throw your body round and turn your head and look were you want to go and your body shall follow. Then when your vertical, click your hips and spin out the rest whilst lowwering the front. (Y) ← Hmmm thats going to take a while lol, T'is a good thing i have nothing to do until someone wants to employ me :wub: The bit that has me confused at the mo is starting the spin. Pete Quote Link to comment Share on other sites More sharing options...
N.Wood Posted June 10, 2005 Report Share Posted June 10, 2005 Dont worry about tyre pressures... ← The trouble with that is that your tyre sticks to the floor and when you slow down your bike gets pulled the opposite way 'cos your tyres kinda re-coiling... Hard to explain without a tyre and a floor (Y) But yeh, practise practise practise... Quote Link to comment Share on other sites More sharing options...
Luke Drewery Posted June 10, 2005 Report Share Posted June 10, 2005 Spins are easy when you know the right tecnique, i can do 540's on the rear wheel now after much practice (its my favourite move). The key is to lean into the opposite direction before you start the spin, also turn the handlebars the opposite way too. This gives you good leverage to whip the bike round. When you have started the spin, keep your head facing round the way you are spinning and lean into it to keep the spn going. Practice it and youll get it eventually. Its a really good showoff trick. (Y) Quote Link to comment Share on other sites More sharing options...
Tony Harrison Posted June 10, 2005 Report Share Posted June 10, 2005 Lots of people try and do this with the bike too low. You need your centre of gravity above the rear axle. As you lift off, pull the bike up and keep your body twisted so it's leading the bike. Quote Link to comment Share on other sites More sharing options...
tipsy Jock Posted June 10, 2005 Author Report Share Posted June 10, 2005 Ahhhh is starting to make sense now (Y) Quote Link to comment Share on other sites More sharing options...
JT! Posted June 12, 2005 Report Share Posted June 12, 2005 Whenever i do spins (about 270) i tend not to pedal kick at all. Should i be kicking or not? Quote Link to comment Share on other sites More sharing options...
boon racoon Posted June 12, 2005 Report Share Posted June 12, 2005 spins and shizzle...that's not trials. get a proper bike!!!! www.bmx-forum.co.uk mate :turned: Quote Link to comment Share on other sites More sharing options...
tipsy Jock Posted June 12, 2005 Author Report Share Posted June 12, 2005 spins and shizzle...that's not trials. get a proper bike!!!! www.bmx-forum.co.uk mate :turned: ← You mean one with a seat or something? pete Quote Link to comment Share on other sites More sharing options...
Tomm Posted June 12, 2005 Report Share Posted June 12, 2005 One of these :turned: Quote Link to comment Share on other sites More sharing options...
tipsy Jock Posted June 12, 2005 Author Report Share Posted June 12, 2005 One of these (Y) ← Do you reckon he will swap for an 05 pitbull? :turned: Quote Link to comment Share on other sites More sharing options...
JTM Posted June 12, 2005 Report Share Posted June 12, 2005 Do you reckon he will swap for an 05 pitbull? :turned: ← Boon might? Quote Link to comment Share on other sites More sharing options...
Luke Drewery Posted June 12, 2005 Report Share Posted June 12, 2005 Whenever i do spins (about 270) i tend not to pedal kick at all. Should i be kicking or not? ← No, you dont use a pedal kick as that would throw you off sideways, a proper spin stays on a tight spot. Quote Link to comment Share on other sites More sharing options...
Tomm Posted June 12, 2005 Report Share Posted June 12, 2005 Some people use a bit of pedal to help it round the last bit, if you run out of momentum. Or if you are gonna land at a funny angle, and you just pedal a bit to make the landing nicer :turned: Quote Link to comment Share on other sites More sharing options...
colly Posted June 13, 2005 Report Share Posted June 13, 2005 do it on the wet aswell, thats how i learnt. with a bald high tyre :mellow: Quote Link to comment Share on other sites More sharing options...
