I Bled My Front Brake With Water
rocktrials
Cheers Ryan, but I didnt have any of the magura kit or bleeding gear at all, this is the first time I have ever bled a maggie.
Just done it with water, and I have to say, it fells absolutely great! best feeling brake I have ever felt, a massive improvement! In the end I used the search and found an old post from Biff, and used his technique, which is very very simple and gives a perfect bleed without any equipment needed other than the allen keys (obviously) and a container of water.
Mmmm, water-bled maggies... *begins to dribble*
OK then,
Anyone tried water on louise disk brakes? :-
Any comments?
And when it accidentally freezes...couldn't it burst the joints (around the cylinders or so) and then need a new bleed? (Y)
How long have you been running on water?
Just curious..I may try some day... B)
When the water freezes, the water expands (as we know :P). This simply pushes the pads out :) It acts as though you were gently, slightly pulling the lever, in essence. When it thaws, they just slip back in. Simple as that :S
Haven't needed a new bleed, although I redid the first one 'cos it was poop.
I've been running it for ages now, I think... Since October or something ridiculous. If not longer...
Yeah, that technique is a really good idea if you can be arsed taking the whole brake off the bike (Y)
I didnt take the brake off, just leant the bike over to the side so the handlebar/brake lever was submerged in a container of water. easy as you like, and no way air can get in, only out of the system.
It feels really nice, but I guess the thing is just to keep it out of the cold, maybe I should keep my bike in my room during winter or something! Could be a good oppertunity for some wallride practice each night before I go to sleep. lol.
If it froze and the pads went out til they hit the rim, but it continued freezing (this may particularly effect it if brakes are set up close to the rim), surely it might just crack/split the hosing?
to stop it freezing, put anti freeze in it in the winter... but anyway.. its summer, lets make the most of it and stop 'Willing' the winter to come sooner.. We will ginkse (sp?) ourselves and it will start bloody snowing next week!
thats the technique i did, escept, i did take my brake off and submerge it in water.....so there is absolutely no way for air to get in as both exntrance's and exit's are surround by water, just pump the water in until no air comes out, then tighten bolts back on underwater (Y)
