Ben Geary Posted June 7, 2005 Report Share Posted June 7, 2005 (edited) well the problem is that i've just got some new evo mounts and they wont go on with out the mounts being set up to the side, they look really dodgy and i want them to be straight not all over the place like they are at the minute so i was wondering iff you could help me out. im running rim jam pads what are new, mavic d521, and i have a saracen mad o4 frame. please HELP !! thanks, ben Edited June 7, 2005 by Gears Quote Link to comment Share on other sites More sharing options...
Will Arnold Posted June 7, 2005 Report Share Posted June 7, 2005 you should explain the situation better! could u post some piccys too ? help us to help you :huh: (Y) Quote Link to comment Share on other sites More sharing options...
Ben Geary Posted June 7, 2005 Author Report Share Posted June 7, 2005 sorry can't get any pics up Quote Link to comment Share on other sites More sharing options...
Trials Boy Posted June 7, 2005 Report Share Posted June 7, 2005 Can't you just put the pads in how the old ones were or have you tried? :huh: Quote Link to comment Share on other sites More sharing options...
Ben Geary Posted June 7, 2005 Author Report Share Posted June 7, 2005 yeh and i can't get them to how they were. Quote Link to comment Share on other sites More sharing options...
Bionic Balls Posted June 7, 2005 Report Share Posted June 7, 2005 put the elbow such that it touches against the stay when the mount is upright....if you do that- you'll have the push the pistons in further (and the mount will be straighter). Perhaps your pads are too worn to get them near enough without "tilting" the mount...i don't suppose the narrow rim helps :huh: adam Quote Link to comment Share on other sites More sharing options...
Ben Geary Posted June 7, 2005 Author Report Share Posted June 7, 2005 (edited) i don't want the pads to go in i want them to come out and i have them the furthest they can go and it still rubs and my mounts can't go straight because they will rub even more. Edited June 7, 2005 by Gears Quote Link to comment Share on other sites More sharing options...
Luke Drewery Posted June 7, 2005 Report Share Posted June 7, 2005 I understand what you mean as i had trouble on my old planet x zebdi frame with evo mounts and a d521, all you can do is to make sure the wheel is sat perfectly true in the frame then fit the mounts on loosely with the calipers in them and line one side up (the side that the booster bolts onto) so that the pad is perfectly square to the rim and about a mm away, the easy way to do this is to snap an old cd in half and place it between the pad and rim, then push the caliper onto the cd to keep the aligment square, then move the mounts so that they are straight up. Also check that the plastic elbows are against the frame. Tighten the bolts now and repeat for the other side. Your brake should be square and straight now. :huh: Quote Link to comment Share on other sites More sharing options...
Bionic Balls Posted June 7, 2005 Report Share Posted June 7, 2005 swap the mounts over? then pistons can come out further...unless you already did that :huh: adam Quote Link to comment Share on other sites More sharing options...
Ben Geary Posted June 7, 2005 Author Report Share Posted June 7, 2005 swap the mounts over? then pistons can come out further...unless you already did that :huh: adam ← thanks a mill mate i dent realize it was that. thanks for all the help people!! ben (Y) Quote Link to comment Share on other sites More sharing options...
Chris Cook Posted June 7, 2005 Report Share Posted June 7, 2005 I hate evo mounts the flex loads. I have them on fatty r's. They are quite hard to set yup i thought :huh: Anyway to save making another topic, what bolt booster fit on evo mounts ? And wehat booster ? Quote Link to comment Share on other sites More sharing options...
Ben Geary Posted June 7, 2005 Author Report Share Posted June 7, 2005 yes i was just about to ask about boosters to fit a saracen mad o4, ohhh and yeh evo mounts are crap and they flex like silly string lol. Quote Link to comment Share on other sites More sharing options...
Chris Cook Posted June 8, 2005 Report Share Posted June 8, 2005 yes i was just about to ask about boosters to fit a saracen mad o4, ohhh and yeh evo mounts are crap and they flex like silly string lol.← Yep i have them on the front but this time next week i will be running a hope mini :) so i wont have to bother with them silly mounts the flex loads (Y) I wont be getting a frame or forks with them mounts agian unless i am running disc on it. Quote Link to comment Share on other sites More sharing options...
CurtisRider Posted June 8, 2005 Report Share Posted June 8, 2005 Yep i have them on the front but this time next week i will be running a hope mini :S so i wont have to bother with them silly mounts the flex loads (Y) ← whose would that be :)" he he,boosters, well magura boosters do a fine job as i told you on msn ben, then xtr carbon boosters are rather speacial too but they fit onto the post mounts so you still need to run a magura booster Quote Link to comment Share on other sites More sharing options...
