Hope Mono Mini
ian
hi
i fitted my hope mono mini onto my forks etc and put everything on like the disc etc no dirt under the disk to it runs perfect. when i put the wheel in the disk seems to rub when just riding along.
it seems to be catching on the pads is there nay way of moving them out or something to stop them rubbing or is it just because they are new pads.
but the wierd thing is if i pull the lever slightly there is no rubbing at all.
anyone know what could be wrong?
thanks in advance.
ian
Make sure the pistons arent sticking out at all - if they are, take the pads off and push them back gently with a tyre lever (not a screwdriver as you risk damaging it).
Also if the caliper is rubbing on one side it may be off centre, use the shims supplied to adjust this by putting them between the mount and the caliper. This means you can only move it one way obviously.
To move the other way you need a very fancy tool from hope. The mount facing tool remove off paint or metla to give a straight clean surface and you can take as much off as you need. Not owrth buying one for just one use though about £80 i think. Local bike shop might have one
Trev
Adjust the spacers where the caliper is fitted on.
(Y)
Thatll be what is wrong, it is my old mono mini (i think) - rotor is brand new, pads are new, it's been bled and serviced by hope fairly recently.. so there can't be anything wrong with it apart from that..
Edited by tom!e
Or the mounts might need facing, or the pistons might be sticking out slightly if the lever was pulled at all when not installed because of the reservoir (e.g. in the post)
Hydraulic discs, particularly hope are prone to rubbing on the rotor constantly. My mates have had numerous hope discs from the old m4s to the mono mini (which he runs now) and that rubs slightly. Im not sure that there are any tricks to stop it rubbing apart from those mentioned, but if it is only rubbing slightly then i wouldnt bother with it, its not worth the frustration lol. (Y)
Bottom line is that the mini will probably rub. The old calipers had return springs to pull the pads back, but the newer ones rely simply on the pads being knocked back into place by the disc as it rotates, hence it will rub as it is designed to do so.
I know some don't, but they're the lucky ones...
Hmm... theres a helping hand from the return spring in the lever.
If you pull the brake on, and off again... the pistons do actually return.
A well set-up disc brake does not rub. Fiddle with your shims Ian, as has been said (Y)
