Duck Posted June 2, 2005 Report Share Posted June 2, 2005 Hi I have a team 05 and i was wondering what tensioners im ment to use?. I'm using normal ones at the moment, but they dont work well as the drop outs on the team are very short so i cant pull the wheel back.So does anyone know what im ment to use? Cheers Phil Quote Link to comment Share on other sites More sharing options...
Tartridge Posted June 2, 2005 Report Share Posted June 2, 2005 Snail cams :) Or, ideally, the Echo rear hub with integrated cams. Quote Link to comment Share on other sites More sharing options...
Hobnobs Posted June 2, 2005 Report Share Posted June 2, 2005 Snail cams of david, work very well. Quote Link to comment Share on other sites More sharing options...
Derek Gibson Posted June 3, 2005 Report Share Posted June 3, 2005 would the snail cams fit around a chris king bmx axel? as i am getting a echo team 05 Quote Link to comment Share on other sites More sharing options...
Hobnobs Posted June 3, 2005 Report Share Posted June 3, 2005 Yeah, they go around the bit which goes through the dropout slot so it has to be a generic size, in this case 10mm. Quote Link to comment Share on other sites More sharing options...
