Disc Brake Rub
nb88
Hey all........ i just got some new disc pads for my hope mini and 1 pad is rubbing as the rotor isnt centered. As my old pads were worn it only used to rub on the bit where there was a slight buckle but now it rubs on one pad all the time. I phoned up my lbs and they cant get my disc mounts faced before friday and i need it by then for the dj ride....so anyone got any ideas of how i could sort it out? its on the side where you cant use shims to space it out more :lol:
Managed to sort it out - one of the pistons was sticking out a tiny bit so i pushed it back in with a tyre lever.
And tart that sounds like a really good idea i'll do that if i get the same problem again :lol:
cheers!
nozman.
