Pork Pie Posted May 27, 2005 Report Share Posted May 27, 2005 Yo, Earlier this morning, I got some avid pads through the post as my others fell apart. I put them in, with the spring, and also put an FR-1 lever on instead of the SD5 i'd been running previously. Well, it's being crap, basically. It felt nice, but then after about 5 or so pulls of the lever, the blade came really close to the bar. I kept turning the outboard adjuster, which made it go back to normal. I think the problem is with the adjusters, that even when dialled in, it still wants to go back, even without being turned back, and does. I at first thought this could be the spring, so took it out. It's made no difference though :turned: Ideas would be good :S Ta, Dave Quote Link to comment Share on other sites More sharing options...
CoppellStereo Posted May 27, 2005 Report Share Posted May 27, 2005 maybe you need to pull for cable through at the end of the brake caliper :turned: :S Quote Link to comment Share on other sites More sharing options...
Pork Pie Posted May 27, 2005 Author Report Share Posted May 27, 2005 Maybe I've already done that :turned: Quote Link to comment Share on other sites More sharing options...
Tomm Posted May 27, 2005 Report Share Posted May 27, 2005 You are supposed to adjust the avid with the adjuster dials on the caliper itself. Probably won't solve your problem but might do. Is the bolt that holds the cable in tight? Quote Link to comment Share on other sites More sharing options...
Floyd Posted May 27, 2005 Report Share Posted May 27, 2005 Change the levers back :turned: . ricky :S Quote Link to comment Share on other sites More sharing options...
Luke Drewery Posted May 28, 2005 Report Share Posted May 28, 2005 Change the levers back :turned: . ricky :S ← Yep, make sure the lever adjuster is all the way in then re adjust the brake at the caliper with the cable and pad adjusters... Quote Link to comment Share on other sites More sharing options...
