Will Bar End Shifters Fit On
pashley pro
hi there i was looking at buying an xtr bar end shifter but i was will it fit on my handlebars aswell
Are you talking about the XTR shifters that piggy-back onto an XTR shifter? I'm not sure they're functional without the original shifter in place...
You can use Ultegra (8S) or Dura-Ace(9S) bar end shifters on a normal handlebar as thumb shifters if you make a mount - I used an old 6 speed thumb shifter to make my mounts.
Edd Potts (Dave85) has machined a mount for one too.
Jon
Does not include cables, mounting hardware, or anything else not pictured. This lever is intended as a replacement if you already have this shifter and have crashed and broken it.
Its just a shifter you link with your current one so that you can shift in more than one place.
