Pitball '05
RyanRs
What was the outcome for the people's pitballs that had broken brake bosses?? was it a faulty batch, or what??
i am getin a pitball soon and if it was a faulty batch, what date did these people purchase their frames, as ill try get a newer imported one.
thanx
Ry
its pitbull! PITBULL
Yeah have you spelt that wrong on purpose or are you just messing about, not heard anything about brake bosses braking. I'm sure if there was then there would be a post about it on here, try searching for the topic.
Gaz (Y)
hmmn i guess mine was because when i look at my mounts the side what i cracked is offset by about 5mm so i guess it was that but personaly i wouldnt trust them im going to move on and get a toxsin next (Y)
Pauly
HERE :D"
hmmn i guess mine was because when i look at my mounts the side what i cracked is offset by about 5mm so i guess it was that but personaly i wouldnt trust them im going to move on and get a toxsin next :-
Yeah mines seems to be the same problem... as my mounts are slightly off too (Y)
Watson
