Rims?
dave33
right im gonna need wider rim than my 519 because my pads wont reach the rim, want summit light, but wide enough to fit in a ztomz frame, looks pretty much the same as a pure, was thinkin about a rhino lite rim, summit around that width if that will fit that is
any sugetions of other rims want summit nice and light remember!
cheers people :angry:
New Echo CNC'd rim?
They're pretty light...
38mm wide if my memory serves.
yeah thing is thats wider than id like, id like summit just wide enough to try and keep weight down, would help if i knew the minimum width required for the frame :">
I'm running a sunn ditch witch at the moment, which is basically a rhino lite without eye-lets, it has taken a fair few heavy landings, and i didn't notice any difference in weight over my D521 which i was running...
Seem to be good rims to go for :angry:
yeah iv used a rhino lite in the past and round it to be a good rim took the beatings i gave it, on a par with the d521 not quite as strong but not far off.
does any know if a 521 will be wide enough to fitt the atomz frame?
tioga factory dh rim.....................problem solved
ali how wide are they and whats the weight of them like?
the problem is i dont know the width of the frame brakes!!! but it looks simalir to the pure
Just get a bloody Echo Rim!!!!
No one really cares THAT much about weight anymore, so stop being a weed.
521 = 590grams
Echo rim(new version) = Approx. 600grams
(N)  :angry:
f**k sake cant people answer my questions, iv asked a few simple questions and if people dont know the answers to them then please dont post random crap tellin me to get this and that, once i have the info i need then i will make my choice.
so question as follows
1.whats the distance between the brake pads on the ztomz frame?
thanks for ur help lads (N)
thanks for ur help lads :angry:
im guessing the frame will have the brake mounts to fit most rims as otherwise it would be a bit of a shit design. you know or think it wont fit mavic rims so go for somthing else, theres loads of other rims around. get bob
well if u havnt noticed im trying to find out what rim would be the best. and to do that i need info :angry:
thanks for ur help lads (Y)
You already have the frame right? thats how you no your rim will not fit? Why don't you just measure it yourself? :S
f**ksake if i had the frame i would measure it, some people........... (Y) i know from looking that a mavic f519 will not fit as its about 23mm wide
So phone who ever your buying the frame off and ask them to measure it. Some people. :S"  (Y)
all im doing is asking a simple question some one here may beable to tell me, you dont know so why are you still posting shit?
too much hassle if you ask me, you seem a bit picky and i don't actually know whats going on now, 1st you said you have F519's which will not fit, but now you;re on about you don't even have the frame, so....err (Y) what???
how exactly would you know it won;t fit if you don;t have a the frame yet?.... and i would assume most frames, if not all would take an echo nicely, and its light in my opinion. others such as RONNIE, (rear onza rim is also the same width as an echo) or the REGGIE,(the front version of RONNIE which is 32mm wide/doublewall) so thats that..
if you don't like our help and keep being a mong then just go to a bikeshop and tell them to fit you a rim that will work with whatever set up you've got at the moment.
steve
steve
the reason i know a 519 wont fit is because iv seen loads of pics of the frame built up with koxx rims, and my ashton which a 519 fits in is far to narrow for a koxx rim.
the reason im being picky is because i have ti spokes yes thats over £100 worth and i dont want to replace them just so i can use what ever rim i see first.
so i know my spokes will be ok to build up on to a 521 but they wont be long enough for an echo rim or an onza rim.
so stop posting shit
Why not just say that you're having to make sure your ti spokes fit in the build at the beginning? Have a look for yourself on CRC, they have lots and lots of rims, you're sure to find one in between Echo and 521 width (Y)
If all else fails, you could probably sell your ti spokes and get some normal ones (which will be just as good) and have a choice of whatever rim you like - I'd personally go for a Ronnie/Echo rim.
