Which Rim
Whiteboy
ok well its new front rim time and syuck beetwen to rims. 1st being a tioga dh disk on would drill with 22mm holes beetween spokes and then sthe sidewall like bigmans done on his dx32 to save some weight or the second option would be a dx32 wich is wider, cheaper, but a bit hevier and do the same drillings. which do you think? tioga is 25 quid and i can pick a dx32up for about 15-20 quid.
thanks
thanks
Wider and cheper then you can drill more holes to make up for the extra weight gained (N) :angry:
Craig
nah! go dx32 on the front!!! i run a wider front rim than rear rim!!! (38 rear, 40mm front :angry: ) massive front rims rule!!! get a sweet 2.3 tyre on it, and reap the rewards. and if u mention weight, i'm gonna cry.... performance to weight ratios matey! thats where its at!
smithy
