oakley Posted May 24, 2005 Report Share Posted May 24, 2005 orite guys and girls, on my magura marta when i let go of the lever it drop a little bit more, as if it's loose. so it is a long way a way from my bar when i next go to pull it! does any one else have this problem and how do you fix it! thanks in advance! joE! (Y) Quote Link to comment Share on other sites More sharing options...
Biff Posted May 24, 2005 Report Share Posted May 24, 2005 ok my mate had this similar problem, there should be a small cone shaped screw where lever joins? that came out on his and all he did was take lever out and replace the cone shaped bolt thingy back in the correct way! The bolt is holding the lever in place Quote Link to comment Share on other sites More sharing options...
oakley Posted May 24, 2005 Author Report Share Posted May 24, 2005 ok my mate had this similar problem, there should be a small cone shaped screw where lever joins? that came out on his and all he did was take lever out and replace the cone shaped bolt thingy back in the correct way! The bolt is holding the lever in place ← mine came out aswell so i put another one in but it still has the same problem. it doesnt't affect the power of the brake or anything, it is just annoying, and makes the lever harder to reach! thanks guys! :angry: joE! Quote Link to comment Share on other sites More sharing options...
