ian Posted May 24, 2005 Report Share Posted May 24, 2005 hi i am thinking of getting a hope mono trial, when looking on tartybikes.com where i am more than likely to buy it form was wondering is it worth paying £10 more to get the bigger rotor size. and is there any difference in power or anything else between the two and has anybody used either or them. thanks ian Quote Link to comment Share on other sites More sharing options...
CurtisRider Posted May 24, 2005 Report Share Posted May 24, 2005 bigger disc everytime!!! unless you ride a mod and are about 6 stone.... bigger discs are well worth the extra money, you wont regret it (Y) Quote Link to comment Share on other sites More sharing options...
Stanners Posted May 24, 2005 Report Share Posted May 24, 2005 Definatly get the bigger roter. It not only looks better but they work absolutly mint. Plus you don't have to set it up every other day so it works good.Cough~magura~cough (Y) :D :D Quote Link to comment Share on other sites More sharing options...
Towler Posted May 24, 2005 Report Share Posted May 24, 2005 My 160 works fine (Y)" Quote Link to comment Share on other sites More sharing options...
ian Posted May 24, 2005 Author Report Share Posted May 24, 2005 ive had a magura i had an avid mechanical and sold it then went back to a magura. my magura finally broke well the TPA but i cant really be bothered to fix it. is there any difference apart from power. Quote Link to comment Share on other sites More sharing options...
hugh_b Posted May 24, 2005 Report Share Posted May 24, 2005 I have a 160 on my monotrial and it is better than my fully bedded in magura marta by a long way. I have only ridden up and down the road and it's all ready better (Y) -Hugh Quote Link to comment Share on other sites More sharing options...
Burton Posted May 24, 2005 Report Share Posted May 24, 2005 Go for the 180 rotor..the 160 un felt like it lacked power, grab and hold. Quote Link to comment Share on other sites More sharing options...
ScotchDave Posted May 24, 2005 Report Share Posted May 24, 2005 I know that theres some people on here who weigh as much as me (13 stone) and use a 160 perfectly happily, however I got a 180, cos I felt my lard arse would need it. :D (Y) In other words, if yer heavy get a 180, if not save the 20 or so grams and get a 160. However a bigger disc will require less power from the rider (marginally) so maybe it would be better to go for that to lessen arm pump if you have trouble with it. :D Quote Link to comment Share on other sites More sharing options...
ian Posted May 24, 2005 Author Report Share Posted May 24, 2005 what do you mean by then end bit of your reply 'div'? bit confussed. Quote Link to comment Share on other sites More sharing options...
Tom-ass Posted May 24, 2005 Report Share Posted May 24, 2005 bigger disc = more leverage therefore, your braking is better with the same amount of finger squeeze its an amazing disc brake and the 160 is perfectly sufficient, however, you can get a 180 for only 10 quid more, so why not??? tom Quote Link to comment Share on other sites More sharing options...
ScotchDave Posted May 24, 2005 Report Share Posted May 24, 2005 Tom got it on one. (Y) Quote Link to comment Share on other sites More sharing options...
mehukatti Posted May 24, 2005 Report Share Posted May 24, 2005 is the weight difference between 160 and 180 only 20 grams? Quote Link to comment Share on other sites More sharing options...
Tartridge Posted May 24, 2005 Report Share Posted May 24, 2005 50g. 408g for the 160, 458g for the 180mm version. Thats for a front, full length hose, and all mounting hardware. Quote Link to comment Share on other sites More sharing options...
ScotchDave Posted May 25, 2005 Report Share Posted May 25, 2005 Sorry, I didn't look it up. :"> Was too lazy, but I knew it was almost nothing. :angry: Quote Link to comment Share on other sites More sharing options...
