zoojames Posted May 12, 2005 Report Share Posted May 12, 2005 Hey guys, I just got my onza ronnie back from being built and have put it back in (used to be a koxx rim) My Magura tpa went today so now have to set up my brake as close the rim as possible, I've now found that I cant get one side any closer to the rim and the brake feels horrible it pulls so far in (im used to a solid brake) Any tips on how to stop this? Im running Heatsinks which have worn down a fair way in funny angles due to having evo mounts and a grind on me old zebdi... James (N) Quote Link to comment Share on other sites More sharing options...
JT! Posted May 12, 2005 Report Share Posted May 12, 2005 If it's the 04 maguras, bodge it! Look in the FAQ's. Problem solved. (N)" Quote Link to comment Share on other sites More sharing options...
Tricky Posted May 12, 2005 Report Share Posted May 12, 2005 If one piston moves more than the other, you've got air in the brake somehow. Most probably in the bridge hose. Bleed your brake. Which will be tricky if your lever adjuster in buggered. If your pads are to bad, buy new ones. The more rubber contacting the rim surface the more solid the brake will be Quote Link to comment Share on other sites More sharing options...
zoojames Posted May 12, 2005 Author Report Share Posted May 12, 2005 Talking to Dave@Tartybikes Its because the wheel hasn't been dished properly...meh oh well back to the shop tomorow! James (N) Quote Link to comment Share on other sites More sharing options...
gazmaz03 Posted May 12, 2005 Report Share Posted May 12, 2005 I think the best problem to solve this is to get a magura bolt the goes into frame 4m and put it through your T.P.A then it will work the same i have seen loads of people do it. That way you don't even have to try and set your pads up to the rim as close as you can although it would be good :) . Just ajust it as normal. Hope I was off some help. Gaz (N) Quote Link to comment Share on other sites More sharing options...
