Long Yaabaa Frames
PaRtZ
I've just been looking around and the yaabaa mod frame seems like a good frame: 80g heavier than a levelboss, £175 (=8¬O) but i think the only problem is its too short at 1000mm. Im riding a dabomb at the moments, and i want something longer (although im not sure what my current wheelbase is)
So basically im just asking if anyone knows if Yaabaa are likely to make a long karaoul (mod) frame. Cheers
It'll be about a billion times better than a DaBomb. That said, you'd be better off going for a T-Pro frame, which is basically the same as the Koxx Levelboss frame. Dunno how much they are at RRP (Probably about the same as the Yaabaa), but you can certainly get them 2nd hand for less money - Under £100.
