lego Posted May 11, 2005 Report Share Posted May 11, 2005 (edited) Could I remove the rear sprocket with an oil filter remover? looks the same as the proper sprocket remover tool. Oh yeah and which way do you turn it :- Edited May 11, 2005 by lego Quote Link to comment Share on other sites More sharing options...
Guest Posted May 11, 2005 Report Share Posted May 11, 2005 do you mean from an 7 8 or 9 speed one or one of a mod type thing. if its off a mod yes but they are very hard to get off i hade to get an angle grinder 2 one to get it off if you can put the sprocket in a vice and turn the wheel hope this helps and they turn atiyclockwise[sp] Quote Link to comment Share on other sites More sharing options...
Lawnmowerman Posted May 11, 2005 Report Share Posted May 11, 2005 wrap the chain whip around the cog so it wont move, then use a proper cassette lock ring tool and undo anti clockwise :- Quote Link to comment Share on other sites More sharing options...
lego Posted May 11, 2005 Author Report Share Posted May 11, 2005 ah I need another tool (lock ring tool)...wondered how they did it :-" Quote Link to comment Share on other sites More sharing options...
Lawnmowerman Posted May 11, 2005 Report Share Posted May 11, 2005 you'll need one of these. Make sure you get the right one though as the freewheel removal tool is very similar and wont work :- Quote Link to comment Share on other sites More sharing options...
lego Posted May 11, 2005 Author Report Share Posted May 11, 2005 thanks for the link. Quote Link to comment Share on other sites More sharing options...
Jonny Shoe Posted May 11, 2005 Report Share Posted May 11, 2005 I'm sorry for stealing the thread but I am just about to put my sprocket on a new hub and I was wondering if most mod sprockets are universal? Thanks :- Quote Link to comment Share on other sites More sharing options...
Mark W Posted May 11, 2005 Report Share Posted May 11, 2005 Sure are, unless you've got a flip-flop (threads on both side) hub, and you're trying to put it on the micro-drive side, in which case it won't fit. Other than that, every screw-on sprocket will fit every mod hub or front freewheel crank :- Mark Quote Link to comment Share on other sites More sharing options...
Jonny Shoe Posted May 11, 2005 Report Share Posted May 11, 2005 Thanks very much that will save me a few bob. :- One more thing what is the average gear ratio on a mod just in case I may have to swap my sprocket. Quote Link to comment Share on other sites More sharing options...
mtbsteveo Posted May 11, 2005 Report Share Posted May 11, 2005 I believe most mod riders run an 18 tooth on the front and a 12 tooth on the rear, but it is personal preference, on my mod i have a 17 tooth on the front and a 12 on the rear. Quote Link to comment Share on other sites More sharing options...
Mark W Posted May 11, 2005 Report Share Posted May 11, 2005 Auto Reply The topic starter has been validated. Moving topic from New Members Chat to Trials Chat. Quote Link to comment Share on other sites More sharing options...
Guest Posted January 16, 2006 Report Share Posted January 16, 2006 Auto ReplyThe topic starter has been validated. Moving topic from New Members Chat to Trials Chat.Bump from the grave, I buggered up my rear cog tonight by having my chain too tight, where is the cheapest place to get cogs? I can only see one's for £20 on cleanbikes and tartybikes..... Quote Link to comment Share on other sites More sharing options...
