TrialsBoy22 Posted May 10, 2005 Report Share Posted May 10, 2005 Are these rims made of cheesy metal like the Try-Alls? Or do they hold a grind well like the Alex DX-32? THanks Byron Quote Link to comment Share on other sites More sharing options...
TheMunn Posted May 10, 2005 Report Share Posted May 10, 2005 They are the stronger metal version of a koxx rim, so should be fine with a grind on it. Quote Link to comment Share on other sites More sharing options...
Bigman Posted May 10, 2005 Report Share Posted May 10, 2005 They are the stronger metal version of a koxx rim, so should be fine with a grind on it. ← Um, seeing as they are EXACTLY the same rim, apart from the eyelets i can not see them holding a grind for long. Adam Quote Link to comment Share on other sites More sharing options...
Corish Posted May 10, 2005 Report Share Posted May 10, 2005 Koxx rim but with eye lets and hedge hogs instead of holes :- corish Quote Link to comment Share on other sites More sharing options...
munkee Posted May 11, 2005 Report Share Posted May 11, 2005 Koxx rim but with eye lets and hedge hogs instead of holes :- corish ← no hedge hogs on mine... just holes for me ( rear ) Quote Link to comment Share on other sites More sharing options...
SCOTTY___ Posted May 11, 2005 Report Share Posted May 11, 2005 Koxx rim but with eye lets and hedge hogs instead of holes :- corish ← You get a choice. They come in circles and hedgogs. Scotty Quote Link to comment Share on other sites More sharing options...
Tricky Posted May 11, 2005 Report Share Posted May 11, 2005 Suprisingly good rims. F.rims are with Hogs in them because the hog is stamped from the metal in production. This can be done as the F.rims are only single wall. Others above are correct. The r.rims are Tri-all rims. They come out of the same factory in the far east. They just dont have Tri-all etched on them. The r.rims must have round holes in as if the hogs where stamped through, the cutter would bend the first wall of the rim. So they a milled out round. Grins vary and it depends on the grind, pads used and the rider to how long they last. Quote Link to comment Share on other sites More sharing options...
