Front V-brake
DaiTrials
Hey can you all post here what you think the best V-brake is for trials. and also the best lever and pads.
I've been advised to get a single digit 7, with the digit 7 lever, and jagwire pads. If anyone has a better combination I should conside let me know.
Dai
XTR arms, XTR lever, Nokon Cable, Plazmatic CRV/V-fly pads, or Coustellier pad in Plazmatic CNC holder, with XTR booster and ground rim.
Maybe Avid Ultimate arms instead of XTR, if you don't want the parallell push system.
The Single Digit SL are a waste of money, if you want cheaper, get SD7.
Me and fred experimented with his front V (avid SD5 arms and lever i think (Y) )
we put on some Fibrex XTR cartridge pads with the red insert and gave his mavic rim a light grind. The lock and power of the brake was actually amazing although the modulation was some what lacking ;)
Not to sure weather he is still using this setup or not but if he sees this post im sure he will reply
cheers Gavin
Avid Ultimate clipers
Avid Speed dial / Xtr levers
Nokon cabels
Koolstop / plazmatic pads
thats about as good as your gona get
you could get an Ultimate lever but you wouldn't gain much
I'm selling this brake very soon if anyones intrested (Y)"
