RyanMcVicker Posted April 28, 2005 Report Share Posted April 28, 2005 Haven't posted here in a while... hello everyone! Does anyone run a 2.2 michy comp24.1 in rear? what does kenny b. / vinco use front and rear?? i want to use michelin front/rear, but dont know which ones to get yet.... ryan Quote Link to comment Share on other sites More sharing options...
CoppellStereo Posted April 28, 2005 Report Share Posted April 28, 2005 i have the 2.5, its a lot smaller than most 2.5's (Y) Quote Link to comment Share on other sites More sharing options...
Ingram Posted April 28, 2005 Report Share Posted April 28, 2005 i have the 2.5, its a lot smaller than most 2.5's (Y) ← I 2nd that, i thought mine was small, but yer the 2.5 are smaller than normal 2.5 tyres. Quote Link to comment Share on other sites More sharing options...
The Dude Posted April 28, 2005 Report Share Posted April 28, 2005 i used to have the 2.2 and it felt unreally steable, and never felt i needed any more width. Quote Link to comment Share on other sites More sharing options...
Rush Posted April 28, 2005 Report Share Posted April 28, 2005 CT AND Coppelstereo!! Use the 2.5 if youre heavier like me, the 2.2 if youre lighter. The 2.2 will be great for lack of tyre roll. Quote Link to comment Share on other sites More sharing options...
RyanMcVicker Posted April 29, 2005 Author Report Share Posted April 29, 2005 this forums email notifaction thing doesnt work? RUSH!! iam about 180lbs, what do you think? i like protection for big gaps, but also like stable tire for rocks that are on an angle.... peace ryan Quote Link to comment Share on other sites More sharing options...
CoppellStereo Posted April 29, 2005 Report Share Posted April 29, 2005 hey its Rush! and ctfal Tires size different from different brands. crazy huh? (Y) My IRC 2.5 would not fit on my bike at all with the BT5.0's chainstays, so i found this WTB 2.4, and it barely fit, but now my mich comp 24.1 fits a whole lot better that the 2.4 did. Quote Link to comment Share on other sites More sharing options...
fairy elephants Posted April 29, 2005 Report Share Posted April 29, 2005 Well I personally have just purchased a 2.2 comp 24.1. I used to use on way back, then got a very bouncy 2.5 hot-s, then I went for the 2.35 maxxis. My friend recently got the 2.2 comp 24.1, and it looks a fair bit wider than the 2.35 maxxis minnion, so I thought i'd give it ago again. If all you want from a tire is good grip and puncture protection then the 2.2 should be ample. The 2.5 will weigh more, but should be more bouncy. I would also concider what rim your using before buying. If you are using somthing narrow such as a D521/ EX721 then the 2.2 will not roll as much as the 2.5 would. But, If you have got somthing like a Koxx or Onza rim, the 2.5 might be better. Hope this has helped. Alex. Quote Link to comment Share on other sites More sharing options...
HarshRider Posted April 29, 2005 Report Share Posted April 29, 2005 doesnt the size of the tyre change with height? for example! the bigger it is the higher it goes to the booster? thats what i thought! Quote Link to comment Share on other sites More sharing options...
RyanMcVicker Posted May 2, 2005 Author Report Share Posted May 2, 2005 i have a echo rim aka dx32 like 38mm wide Quote Link to comment Share on other sites More sharing options...
Janson Posted May 2, 2005 Report Share Posted May 2, 2005 The 2.2" is going to feel pretty low on that rim.. Very stable and 'dead' feeling, will never pinch, but takes some effort fitting it on the rim. Should last longer than a Maxxis, and flex less. Quote Link to comment Share on other sites More sharing options...
N.Wood Posted May 2, 2005 Report Share Posted May 2, 2005 Jeez, it's like OTN in here! Hehe, welcome to England (Y) Tyre wise, i'd never bother running a Michelin Comp 16/24 2.5, it's just too heavy and un necesarally beefy. A 2.2 is all i'd ever want from a Michelin, though i'd never buy a 2.35 Maxxis, it'd always be a 2.5. I say go 2.2, save some weight and have better mud clearance. Good luck! Quote Link to comment Share on other sites More sharing options...
Rush Posted May 2, 2005 Report Share Posted May 2, 2005 doesnt the size of the tyre change with height? for example! the bigger it is the higher it goes to the booster? thats what i thought! ← :wtf: ? Quote Link to comment Share on other sites More sharing options...
Krisboats Posted May 3, 2005 Report Share Posted May 3, 2005 :wtf: ? ← he means that the tyre size (2.1 inches, 2.5 inches, 72.9 inches..etc) relates to the depth of the tyre not it's width. a 2.5 will be closer to touching the seat tube and the brake bosster than a 2.2 would because it is taller. go for a 2.5, they're super cool. and from here they're only £20. linky to cheap tyres Quote Link to comment Share on other sites More sharing options...
HarshRider Posted May 3, 2005 Report Share Posted May 3, 2005 he means that the tyre size (2.1 inches, 2.5 inches, 72.9 inches..etc) relates to the depth of the tyre not it's width. a 2.5 will be closer to touching the seat tube and the brake bosster than a 2.2 would because it is taller. go for a 2.5, they're super cool. and from here they're only £20. linky to cheap tyres ← cheers for that im not always good at explaining things :blink: Quote Link to comment Share on other sites More sharing options...
Krisboats Posted May 3, 2005 Report Share Posted May 3, 2005 no problemo :blink: Quote Link to comment Share on other sites More sharing options...
RyanMcVicker Posted May 3, 2005 Author Report Share Posted May 3, 2005 thanks everyone Quote Link to comment Share on other sites More sharing options...
