matthewholdsworth Posted April 27, 2005 Report Share Posted April 27, 2005 my laptop just flashed a warning at me that my computer is "low on virtual memory" what is it? i assume it didnt like me editing a video Quote Link to comment Share on other sites More sharing options...
Spikenipple Posted April 27, 2005 Report Share Posted April 27, 2005 How much space is left on your hard drive? You need a certain amount of space (almost always over 400mb) for a PCs 'Swap file' which uses the hard drive as memory to move files around. Try freeing up some hdd space and see what happens :) Quote Link to comment Share on other sites More sharing options...
Tomm Posted April 27, 2005 Report Share Posted April 27, 2005 How much space is left on your hard drive? You need a certain amount of space (almost always over 400mb) for a PCs 'Swap file' which uses the hard drive as memory to move files around. Try freeing up some hdd space and see what happens :) ← Yup that's right. I think ideally, PCs want about twice as much VM as there is RAM. I.e if you have 512MB of RAM, you should have at least 1GB of hard drive space free :) Quote Link to comment Share on other sites More sharing options...
Rob_P Posted April 27, 2005 Report Share Posted April 27, 2005 I also have this annoying problem! I have about 2GB free on my hardrive and an external hardrive where there is 150GB of free space! I'm asuming it's running off the laptop internal memory, am I correct? Rob :) Quote Link to comment Share on other sites More sharing options...
Interested Posted April 27, 2005 Report Share Posted April 27, 2005 I'm always getting that about the virtual memory being low,I usually just reboot and it stops. Quote Link to comment Share on other sites More sharing options...
Bondy Posted April 27, 2005 Report Share Posted April 27, 2005 Deleting a bundle of videos usually works for me :) Quote Link to comment Share on other sites More sharing options...
Tomm Posted April 27, 2005 Report Share Posted April 27, 2005 I also have this annoying problem! I have about 2GB free on my hardrive and an external hardrive where there is 150GB of free space! I'm asuming it's running off the laptop internal memory, am I correct? Rob :- ← Um, it should run off whichever hard drive Windows is installed onto (usually c:), unless you've changed it. (For WinXP pro) Control Panel - System - Advanced tab - Underperformance, click settings - Advanced tab, click the Virtual memory button. Make sure that's set to C:. It's probably not a very good idea setting it to the external drive, as that will be really slow compared to the internal hard drive. Although 2GB should be fine. Quote Link to comment Share on other sites More sharing options...
matthewholdsworth Posted April 27, 2005 Author Report Share Posted April 27, 2005 ive got 3gb left and have done all the video deleting i can leaving only the true gems. its all sorted now, i think my comp just got tired Quote Link to comment Share on other sites More sharing options...
tank_rider Posted April 28, 2005 Report Share Posted April 28, 2005 your best to probably manually set the minimum limit to twice the amount of RAM you have. However before you do that, do a defrag on your hard drive to get all your files in order, and as much free space together as poss. Quote Link to comment Share on other sites More sharing options...
