3 Piece Crank Chain Rings
wally
Just what is the smallest chain ring you can buy for BMX 3 piece cranks. I know there must be a limit, due to the bolt on the crank arm that you tighten the chain ring to.
Can you get an 18 tooth? (Y)
Thanks for your help.
Well i pressume you can get smaller because Rich 4130 was/still is selling a custom 3 pc guard with space to run a 22 t etc?
Yea, its just like a goldtec one, my dad made it me when I mangeled a spider and asked him if he could fix it, kinda evolved identical as a goldtec one, even though I didnt know they existed hehe.
Either get a goldtec one, or get a Macneil 25t bash, run like 20t at the back, be nice, what Luis has on his ET.
I can't remember what it was unfortunately but it didnt really work so it doesnt matter really. It was mainly designed for 1 piece cranks and he had to ovalise the bolt hole which resulted in a big egg which made a nice tight spot in the chain.
Spider/built in bash thing is the way i'd say. You could probably get someone to machine you a bash that small.
I've used the goldtec trials guard for 3pc'ers.
The chainring bolts on the bashguard. the bash then bolts on the cranks. It's great. It has 5 holes to use for the main bolt, so if you waste one side of the guard you can simply spin it around and use a fresh section.
I'd highly recommend it.
I think 18's going a bit too far but many companies manufacture MTB spiders for 3pc cranks.
I ran a really lame cold forged one from some company that went underground years ago, on a pair of chieftans for 3 years and it was fine... this was with the old old middleburn bashguard.
oli
