Pashley Website - Help Me!
Sam Nichols
Right click on the t-v on the left hand corner that says tune in
then a big tv will come up there is a star shaped dial thing move your mouse around the edges untill trials comes up then you should know what to do :lol:
did that make sence? (Y) .
You should know by now that pashley site = Utter wank
Tom (Y)
EDIT: But here's all the info on the frame off the site:
Weight: 5.0 lbs
Colour: Burgundy with gold stickers
Available: March 04
Price: £450 (Frame only)
The area around the BB is created with laser cut and machined steel plates arranged to give good tyre clearance as well as a short rear end.
the dual seat posts are intended to create a space frame chasis that is light and strong in all planes. The seat posts also mount very close to the break mount to eliminate vibration and flex in the seat stay under braking.
The mech hanger also features a replacable unit which does 3 things: 1, acts as a sacrificial hanger, which should snap instead of the frame. 2, relocates the mech in a more forwards position which gives more chain wrap around the cassette spreading the load over more teeth. 3, locks the skewer in position in the axle making it impossible for the rear wheel to move under extreme loads.
· Colour - Burgundy
· 384mm Chainstays
· Unique twin seat tubes
· 73mm BB shell
· Dedicated 4 bolt Magura Mounts
· Reynolds 853 and 725 tubing
· Inverted tear-drop anti-dent down tube
· Includes trials saddle
· Replaceable mech-hanger available
Edited by PythonRider
