Chain Skipping
RyanRs
Help!! AAAARRG!
For no apparent reason, my chain occasionally skips, like when it isn't in gear properly..
i have a KMC kwel chain, all links are good, the cog at the wheel isn't bent, the chain line from the rear cog to the chainring is almost a straight line, and my mech is setup in the right position to keep it on this gear (as i have taken all my other cogs off)
if i turn the pedals anti clockwise, every 1 and half turns of the cranks, the chain jumps as it rolls onto the rear sprocket, like if one of the teeth are bent, but there ok! my chain is tensioned nicely too.
Is it possible my KMC has worn out my rear cog? as they both aint exactly new! I no there are single speed cogs with longer teeth, should i get one of these? and where from?
What is wrong with the bloody thing! its driving me insane as it completely takes my confidence away when going for a gap or even Pedaling fast!!
HEELPPP!
Ry
>_<
You my friend, may have a stiff link >_<
Find it and sort it :turned:
nope, no stiff links. checked every one! expecially where it jumps. but the jumps on the rear cog seem random!
i think trialsboy560 may be correct with the worn sprocket though?? -i hope it is something as simple as this!
Hum, conversion kit..?? where can i get this from and will it work on a zoo pitball?? i fort you have to have horizontal dropouts for these kits?
A conversion kit consists of 2 spacers and a cog usually. You will need a locked out mech or SS tensioner for it to work.
I'm not sure how this wil sort your problem. Check everything in the vacinity as i have said above.
Thanx for the help everyone!
Seems it may have been the rear cog being warn and the general straightness of the chain line, as i have replaced the rear cog and moved it up the freehub a bit to get a perfect chain line with the cranks. the problem seems to be fixed now!
Cheers everyone
Ry
