Hope Mono Info
chrishayton
Hey,I bin out for a ride today and my hope mono hub slipped but not as in the pawls. It just pedaled both ways. When I got home i stripped the hub and found out that the ratchet ring was just spinning. So i think ive threaded it
Has this happened to anyone else?
cheers
chris
Yes I no, i'm going to ring hope tomorrow, but usually the teeth on the ratchet break off or wear down, but in my case this time the ring that the teeth are attached(the part the replace when you normal send it back) has threaded or something as it just spins wen the teeth engage. Thats why i posted just to see if this has happened to anyone else.
