Impacted. Posted April 23, 2005 Report Share Posted April 23, 2005 Good morning, people! I currently have a hope mono trial with a 160mm rotor, and I would like a bit more power out of my front brake than what I have at the moment. So first I wanted to know if this and this would be compatible with my brake, and secondly if you guys think that a 185mm rotor will provide a significant amount more braking power, or should I go straight up and get the 205mm rotor? And also if the fact that having a bigger disk will be less harsh on my disk tabs? Thanks. Quote Link to comment Share on other sites More sharing options...
totaltrials Posted April 23, 2005 Report Share Posted April 23, 2005 (edited) The latest hope brakes are 160, if you use a +20mm or +40mm adaptor you would need a 180 or 200 rotor not a 185 or 205, The adaptor should be fine, but you will need the correct size rotor, otherwise it will probably rub on the caliper. So get a 180 rotor, which are available. You will notice quite a lot more power. try: wiggle There is an aztec rotor and a hope mini 180 rotor on there. Phil. Edited April 23, 2005 by totaltrials Quote Link to comment Share on other sites More sharing options...
Impacted. Posted April 23, 2005 Author Report Share Posted April 23, 2005 Will the aztec rotor work? Because I thought I heard something about hope brakes and wavy rotors not being compatible. And also, would 200mm be worth the money or a bit overkill? Quote Link to comment Share on other sites More sharing options...
totaltrials Posted April 23, 2005 Report Share Posted April 23, 2005 Will the aztec rotor work? Because I thought I heard something about hope brakes and wavy rotors not being compatible. And also, would 200mm be worth the money or a bit overkill? ← A wavey rotor will work with any disc brake, and should be slightly better braking but I never notice any difference. If you can get a 200mm then I would say to get the 200mm. Phil. Quote Link to comment Share on other sites More sharing options...
colly Posted April 23, 2005 Report Share Posted April 23, 2005 yes it should give it a lot more bite and wont get as hot on long downhills if you ever rode one on a trials bike Quote Link to comment Share on other sites More sharing options...
Wayne-king Posted April 23, 2005 Report Share Posted April 23, 2005 have a word with Adam Read (Tartridge) im pretty sure he's running a 200mm+ rotor on his mono trial >_< Quote Link to comment Share on other sites More sharing options...
Michael Hardman Posted April 23, 2005 Report Share Posted April 23, 2005 Im running a 205 m4 and yes the larger the rotor the mor epower. Take a downhill bike, the front brake is used for 75% of the braking and yes the front rotor is as big or bigger than the rear. There is an arguement ithing downhill that there is no need for 200+ discs on the rear of bikes. Quote Link to comment Share on other sites More sharing options...
