Rob_P Posted April 18, 2005 Report Share Posted April 18, 2005 Hey, I made a thread the other day about where to get themes from for XP! I then mentioned at the end that I had a problem but knowone took any notice and I didn't want to fill up the thread with bumps. The problem is that I want to install a crystal XP pack! I had it on there before but it has slowly uninstalled itself form my pc for some strange reason. I have the pack on my PC but when i load it to install it there is an error messge that appears saying I need to delete my current theme first! So I go to properties and then themes, delete all current themes, try again and what a surprise, the same error messgae appears. How do I load this theme and/or delete the current one! Thanks alot Rob Quote Link to comment Share on other sites More sharing options...
Nick Garland Posted April 18, 2005 Report Share Posted April 18, 2005 Have you tryed going to Add/Remove programs and removing the Crystal theme then re-installing it? Quote Link to comment Share on other sites More sharing options...
