Computer Help
Si
Hi
Iv got a laptop and a while ago i put Windows Millenium on it. Problem is the iR isn't working anymore.
Iv been through all the disks i got with it and couldm't find the drivers :blink:
The laptop doesn't seem to be made of any company (no branding)
So what could i really do?
Thanks
In device manager it comes up with "Other Devies - Serial infrared port" with a question mark. When i go into the properties it says there is no software installed. but i dont know what make the laptop is so i dont which software to een start looking with :(
i could never get the ir working on my laptop, until i went in to the bios settings ( the bit where you like press f2 on startup) and found that the port was disabled so i just had to re-enable and once restarted windows recognised it and installed.
Aye, but if windows has already recognised it, then it's not a BIOS problem.
have you tried a simple driver update from the device manager, expand the device that isnt working correctly, right click then update driver, it may ask you if you want to look online for it, allow it to do this and it may well sort your problem.
Either that or try running the windows update software, then look in the drivers section, you may find it sitting waiting for you there.
The internet is setup and plus i have broadband
