Ingram Posted April 13, 2005 Report Share Posted April 13, 2005 Hi, Two qestions, how do you get the piston out once the lever blade is off? What size O-Rings do they take? Thanks alot. Jake Quote Link to comment Share on other sites More sharing options...
TheMunn Posted April 13, 2005 Report Share Posted April 13, 2005 Have you checked out the rb web site ? they might have exploded drawing's or something on there. Quote Link to comment Share on other sites More sharing options...
Whiteboy Posted April 13, 2005 Report Share Posted April 13, 2005 where the little bleed grub screw is with the bb behind it. take that out remove the bb and poke a old spoke or small allen key and push the piston out. seals are avadible from steve@heatsink if you need new ones. but there something like 12mm inner and 14 outer or something i dunno. Quote Link to comment Share on other sites More sharing options...
Ingram Posted April 13, 2005 Author Report Share Posted April 13, 2005 ah right kool thanks, mine dont actually have a bb in, on the bleed screw its cone shapped dont leak from there though meh seals are nackered :ermm: cheers Quote Link to comment Share on other sites More sharing options...
Punkrider Posted April 14, 2005 Report Share Posted April 14, 2005 (edited) I have a packet of seals from Heatsink, that i don't need, add me to MSN if interested Adam Edited April 14, 2005 by Punkrider Quote Link to comment Share on other sites More sharing options...
Waynio Posted April 15, 2005 Report Share Posted April 15, 2005 i was going to say, see steve @ heatsink about spare seals. just poke a spoke through the bleed hole and it will pop the seal and plunger unit out. Waynio........................ Quote Link to comment Share on other sites More sharing options...
