Othread Pithch Of A
Whiteboy
Also, the other bits are different. Mech bolts aren't threaded all the way down, and the amount of thread, the length, the thickness of the unthreaded bit all vary from one mech to another (I think). So you'll be lucky to find a random bolt that will fit your mech properly. On the other hand, if you're creating some crazy tensioner job, then 30mm sounds about right (Although maybe you should measure?).
