Bedding In Organic Pads
guineasmithpig
Cover the brake in water and ride down hills with it half on until it stops honking like a goose then spray more water and repete until it works good.
Also you said it was 475, Machanical right? Adjust the inboard static pads as close to the rotor as possable then use the barrel adjusted to get the lever reach you want. (don't touch the rotor brake surface with your sticky little fingers).
Edited by bluecatracingcat
