Ea70 Vs Ta
ONLY
I have a bar question. Now i ride Easton EA70 low rise, but wanna buy riser Try-All bar. The question is: what should i expect? EA70 is 695 mm, that is much shoter then 740 mm's TA. What would be easier to do, and what harder to do, if i had TA bar? Thank you!
Ha, funny you should ask. I went from an ea70 to the new tryall bar.
The extra width gives you much more stability as expected, so back wheel balance is improved, I also find that the extra reach enables me to stand up more UCI'ish on the back wheel (with the bars into my chest)
X ups are a no no now though (unless you want dislocated shoulders) dependingon the length of ur stem.
hope this helps.
Rob
