Magura Hs33 2005
bristol_base
hi guys I have just received a set of 2005 mags from supercycles with '4 bolt mounts' instead of the usual evo mounts, however there is no boosters in the set
is this normal when they sell them with 4 bolt mounts?
do most people still run a booster on 4 bolt mounts?
cheers
al
When i got a pair of 4bolt ones from there last time, I rang them up and said about the missing boosters
They said I didnt need them due to there being 4bolt mounts insted of the 2 bolt ones  (Y)
yer its true, it is not nesesarry for them to be there for the brake to work, but it does improve power (obviously)
Will
Having a booster can help because when u pedle you can kick the hoseing and things like that and the booster gets in the way and stops the hose moving as much if you get me (Y) .
And it does what a booster does .
I would reccomend getting a booster an rb one or summit :) .
Sam
Ad speaks the truth. With 2-bolt Magura mounting systems, the booster is now integrated to the mounts. However, with a 4-bolt Magura it just isn't. It's not them trying to work their way out of it or anything; they simply don't come with them.
