SamHolmes Posted March 30, 2005 Report Share Posted March 30, 2005 Ive just managed to snap a wheel bolt in the axel :unsure: Whats the easiest way or a way I can get out by tonight and still be able to use the wheel axel Pics Thanks alot, Sam (Y) (Y) Quote Link to comment Share on other sites More sharing options...
wally Posted March 30, 2005 Report Share Posted March 30, 2005 Pliers on the end and turn, or is there not enough material there? Quote Link to comment Share on other sites More sharing options...
Will Arnold Posted March 30, 2005 Report Share Posted March 30, 2005 maybe try the old 'hacksaw a slot and screwdriver it out' technique. looks like there might not be enough material there to do it though :unsure: Will Quote Link to comment Share on other sites More sharing options...
Stan Shaw Posted March 30, 2005 Report Share Posted March 30, 2005 (edited) You could try cutting a screwdriver type slot in the end of the bolt using a hacksaw. Then use a flathead screwdriver to turn it. (Y) Edit: Will beat me to it :unsure: Edited March 30, 2005 by cultiv8ed stan Quote Link to comment Share on other sites More sharing options...
tipsy Jock Posted March 30, 2005 Report Share Posted March 30, 2005 Mole grips :unsure: Pete Quote Link to comment Share on other sites More sharing options...
ScotchDave Posted March 30, 2005 Report Share Posted March 30, 2005 Spanner flats? Try helping it come out by twisting it out from other side if it's well greased and the axle is hollow. Quote Link to comment Share on other sites More sharing options...
Bionic Balls Posted March 30, 2005 Report Share Posted March 30, 2005 put in vice and turn ter other end... i've done this a few veeeeeeeery frustrating times..worst case was to drill a 3mm hole in it and bang in a small allen bit from a socket set (tapered end), then i just unscrewed the socket bit with a spanner and it brought the bolt out too. spray some wd40 in there :unsure: good luck adam Quote Link to comment Share on other sites More sharing options...
SamHolmes Posted March 30, 2005 Author Report Share Posted March 30, 2005 Theres not enoguh material to get hold of it Would it be alrite to cut a slit into the axle aswell and then find a small screwdriver and screw it out ? Quote Link to comment Share on other sites More sharing options...
ScotchDave Posted March 30, 2005 Report Share Posted March 30, 2005 maybe try the old 'hacksaw a slot and screwdriver it out' technique. looks like there might not be enough material there to do it though (Y) Will ← You could try cutting a screwdriver type slot in the end of the bolt using a hacksaw. Then use a flathead screwdriver to turn it. (Y) Edit: Will beat me to it :unsure: ← Quote Link to comment Share on other sites More sharing options...
colly Posted March 30, 2005 Report Share Posted March 30, 2005 drill a hole in it very little one, and thread an easy out in to it, the ones i have have an left thread to you can tap them in tightly then turn the other bolt and it will loosen other than that drill it out and tap it. :unsure: Quote Link to comment Share on other sites More sharing options...
SamHolmes Posted March 30, 2005 Author Report Share Posted March 30, 2005 (edited) I was asking wether it would be alirght to cut into the axle aswell, due to there being hardky any bolt there showing EDIT: I was referring that to DIV's post Edited March 30, 2005 by Python_Sam Quote Link to comment Share on other sites More sharing options...
SamHolmes Posted March 30, 2005 Author Report Share Posted March 30, 2005 Sorted now Thanks for the replys :unsure: Quote Link to comment Share on other sites More sharing options...
spunkey_monkey_boy Posted March 30, 2005 Report Share Posted March 30, 2005 Sorted now Thanks for the replys (Y) ← how ddi you get it out becayuse my bolts rounded off and some time soon i'm going to have to snap the head off to get it out of the frame and then get the rest of the bolt out... Quote Link to comment Share on other sites More sharing options...
SamHolmes Posted March 30, 2005 Author Report Share Posted March 30, 2005 I got a hacksaw and cut a slit in the top and simply screwdrivered it out (Y) Quote Link to comment Share on other sites More sharing options...
