Chains?
KoxXy
Hi i ride a lil 20 and currently have a KMC Kool chain and its great.
Was wonderin if any of you ride with a shadow chain. Its ment to be 5 times stronger then a normal chain and to be honest i think they look great when there on the bike. I know sombody on here has it on there BMX.
They do look very nice ,maby if you cheek the website you want to get it off it will reccomned what teeth to run it with?ime preti sure it should fit as many people i no run it on there bmxes with simila gearing to a mod .
Good luck Sam
Shouldn't be too bad on a mod though shorly, I mean they can just adjust the tensionners, and the chain is made of half links so stretch can't be that bad.
Edit : Unless the metal weakens as the bend straightens out...
Edited by waki
They stretch.
'cos every link has a bend in it, rather than just the normal sideplate shape.
Well there mad for BMX and im ridin a mod which is pretty much the same in the way the drive is done and its 5 times stronger then normal chains and as long as it dnt stretch as bad as the KMC Kool chain then im happy! i'll go for the shaddow chain!
