Making A .gif Actually Viewable
Mr Motivator
What's the image like?
Is it a photo, with lots of colours, or even a plain image, but with smooth transitions between colours? If so, then don'r use a gif. You'll have to use a very high amount of colours, and even then it won't be as good as a jpeg, but be a lot bigger file size.
If it's a plain image, with few colours, then yeah, use a gif. And if you're using a semi decent imaging program, then select the amount and which colours you'll be using. Then you can get a crisp image, with a tiny file size.
Either work from scratch in photoshop, or export the image as a 24bit bitmap then export it from p/s as a gif. (Y)
What image is it btw? Might be able to give some better tips on compression.
For example:
http://www21.brinkster.com/takeoffdesigns/pictures.html
If it's a photo, or an image with lots of colours and colour transitions, a selective jpeg compression will be best. (You can select out of 12 on photoshop)
If it's a banner type thing, with very few colours, exporting it as a .gif in photoshop, you can choose the amount of colours you want, and so will give the most effective size to quality ratio. (Y)
Mike.
