Punkrider Posted March 25, 2005 Report Share Posted March 25, 2005 Hi all, I have a Hope braided hose on my rear maggie and i want one on my front Hope Mono M4 (N) I have a really good bleed on my Hope at the moment, when i put the new hose on i don't want to loose it :sleeping: Do you think i will be able to get a good bleed again? What will i need to bleed a Hope? Adam Quote Link to comment Share on other sites More sharing options...
JT! Posted March 25, 2005 Report Share Posted March 25, 2005 (edited) If you do it proporly, it should be as good as it is now. Not sure what you need, but its worth buying, as its nice knowing you can fix it if it breaks. :sleeping: Edited March 25, 2005 by JT! Quote Link to comment Share on other sites More sharing options...
Punkrider Posted March 25, 2005 Author Report Share Posted March 25, 2005 What will i need to bleed it, or is it better to get my LBS do it, as i have never done it before :sleeping: Adam Quote Link to comment Share on other sites More sharing options...
Punkrider Posted March 25, 2005 Author Report Share Posted March 25, 2005 I can either get this Or My friend said something about a bleed kit from my local car spares shop, does anyone know anything about these? Adam Quote Link to comment Share on other sites More sharing options...
Punkrider Posted March 25, 2005 Author Report Share Posted March 25, 2005 Any help wuld be appreciated :sleeping: Adam Quote Link to comment Share on other sites More sharing options...
Danny Posted March 26, 2005 Report Share Posted March 26, 2005 To bleed a hope all you need is some dot fluid, 8mm spanner, and some clear hose :ermm: That kit really isnt required. Quote Link to comment Share on other sites More sharing options...
philking Posted March 26, 2005 Report Share Posted March 26, 2005 All you need to do is buy the correct dot brake fluid, get an 8mm spanner and some plastic hose from a car shop, window wiper hose is the best, i use it and its perfect. Just get the correct size so it fits tightly over the bleed nipple. As for bleeding, just follow the instructions in your hope manual and its so easy. You honestly can't go wrong if you do what it says :ermm: Quote Link to comment Share on other sites More sharing options...
Punkrider Posted March 26, 2005 Author Report Share Posted March 26, 2005 Cheers for the help, i will give it a go :ermm: Adam Quote Link to comment Share on other sites More sharing options...
