Duck Posted March 23, 2005 Report Share Posted March 23, 2005 Hi My rear hope bulb has started to wobble when i rock the wheel,i took the wheel out but there was no movment in the axle but the freehub body moves side to side a few mil and can just be pulled of easy,i took it all apart and gave it a good cleaning but its still doing the same,anyone else had this problem? Phil Quote Link to comment Share on other sites More sharing options...
CurtisRider Posted March 23, 2005 Report Share Posted March 23, 2005 how old is it? maybe the freehub bearings are dead, or the axle is bent? Quote Link to comment Share on other sites More sharing options...
The enchanted broomstick Posted March 23, 2005 Report Share Posted March 23, 2005 i think its that little bit that you pull off the the inside of the freehub which allows you to release the freehub body. i had this problem cos mine had developed a bit of movement and everytime i took the rear wheel out my freehub would fall off so i got one of them new little bits and it clipped on really nice and snug, job was done for me >_< Quote Link to comment Share on other sites More sharing options...
froggy Posted March 23, 2005 Report Share Posted March 23, 2005 i think its that little bit that you pull off the the inside of the freehub which allows you to release the freehub body. i had this problem cos mine had developed a bit of movement and everytime i took the rear wheel out my freehub would fall off so i got one of them new little bits and it clipped on really nice and snug, job was done for me :ermm: ← Yeah what he said! I had exactly the same problem with my hope XC however it ended up I had snapped the axel, booo >_< Quote Link to comment Share on other sites More sharing options...
bluecatracingcat Posted March 23, 2005 Report Share Posted March 23, 2005 (edited) Replace your freehub bearings. With the freehub off use a screw driver to move the spacer off centre then use cerclip pliers to remove cerclip retaining the inside bearing then knock this one out, then knock the outside bearing out the inside hole. Then insert new bearings in the reverse order. I haven't done it in a while but I think it's correct, might want to check though. I'll see if I can find out more info. Leon hopetech Try this^^^ Maintainence rear cassette hub. Edited March 23, 2005 by bluecatracingcat Quote Link to comment Share on other sites More sharing options...
