thechink Posted March 21, 2005 Report Share Posted March 21, 2005 woot look what i found. coule be quite kewl. Wooooootors anyone know anything or got any pics. thechink Quote Link to comment Share on other sites More sharing options...
TheMunn Posted March 21, 2005 Report Share Posted March 21, 2005 First i've heard but look's like a rather good idea, I can see lot's of hurt finger's trying to move the chain over though. Quote Link to comment Share on other sites More sharing options...
JT! Posted March 21, 2005 Report Share Posted March 21, 2005 The idea is you run them with the double chainring cranks. So you physicly move the chain. If you move the chain from a big cog to small cog at the front, and move the chain from a small cog to a big cog at the back. (And visa versa) you get 2 seporate gears, with the chain been kept at the same length, therefor the same tention. :S Quote Link to comment Share on other sites More sharing options...
thechink Posted March 21, 2005 Author Report Share Posted March 21, 2005 thats pimpin. i might try that out next. a riding gear to get you there and a trials gear. thechink Quote Link to comment Share on other sites More sharing options...
ben_travis Posted March 21, 2005 Report Share Posted March 21, 2005 ah jt, u serached google much faster than i did, i was looking at this about 5-6months back at work, seems like a decent idea for u street riders who fancy two gears cheers ben Quote Link to comment Share on other sites More sharing options...
JT! Posted March 21, 2005 Report Share Posted March 21, 2005 (edited) They have to be run on the double chainring cranks: IN - 35/19 = 1.84 OUT - 38/16 = 2.38 Both way too high gearing for trials :D You can't just run the freewheel on its own, with a single chain ring cranks or run it on the front with a 12t cog, as you would definatly have to undo the wheel. This probably wont work, as you wouldn't have enough chain. So if you wanted to change the gear, you would have to alter the length of your chain. :S nice thought though. Edited March 21, 2005 by JT! Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted March 21, 2005 Report Share Posted March 21, 2005 They have to be run on the double chainring cranks: IN - 35/19 = 1.84 OUT - 38/16 = 2.38 ← Or just run a single ring up front, and some form of chain tensioner? :S Quote Link to comment Share on other sites More sharing options...
thechink Posted March 21, 2005 Author Report Share Posted March 21, 2005 or if you run a stock with front freewheel. woot. thechink Quote Link to comment Share on other sites More sharing options...
JT! Posted March 21, 2005 Report Share Posted March 21, 2005 Or just run a single ring up front, and some form of chain tensioner? :D ← Oh yeah, never thought of that. :D Then your only problem is getting your hands oily :S Quote Link to comment Share on other sites More sharing options...
mark-399 Posted March 21, 2005 Report Share Posted March 21, 2005 Or just run a single ring up front, and some form of chain tensioner? :S ← or for the same money they will prob charge for the freewheel get a stadard one with a nice lil 8 speed cluster :D" Quote Link to comment Share on other sites More sharing options...
JT! Posted March 22, 2005 Report Share Posted March 22, 2005 or for the same money they will prob charge for the freewheel get a stadard one with a nice lil 8 speed cluster :S" ← Or just get some spacers and 2 cogs. Quote Link to comment Share on other sites More sharing options...
Bionic Balls Posted March 22, 2005 Report Share Posted March 22, 2005 I don't know if it'd work up front chinky...since the actual teeth are further over (not central on the freewheel), the chain might rub on your bashring when in one of the gears :S still...worth a try- you first! adam PS: i don't suppose they do a trials version with 72 engagements...wil they? Quote Link to comment Share on other sites More sharing options...
aust Posted March 22, 2005 Report Share Posted March 22, 2005 my friends got a double freewheel.. no the white ind but they have been out for quite a while.. :S Quote Link to comment Share on other sites More sharing options...
colly Posted March 22, 2005 Report Share Posted March 22, 2005 ow much ratio gap would you be able to achieve? Quote Link to comment Share on other sites More sharing options...
JT! Posted March 22, 2005 Report Share Posted March 22, 2005 ow much ratio gap would you be able to achieve? ← Depends what you have on the front. Quote Link to comment Share on other sites More sharing options...
andyzplace Posted March 22, 2005 Report Share Posted March 22, 2005 wouldnt you have to move the wheel to change gear anyway. making it stupidly fiddly and annoying. bit of an arseache for trials, nice idea though. Quote Link to comment Share on other sites More sharing options...
