sammerz Posted March 19, 2005 Report Share Posted March 19, 2005 Does anyone knoe if Zoo pads work better with or without a grind? :"> Sam Quote Link to comment Share on other sites More sharing options...
trialsking 55 Posted March 19, 2005 Report Share Posted March 19, 2005 WITH!!!!!!!! they lock sooo welll with an average grind and they really dont wear that fast. they are not tooo good without a grind in my experience :o Quote Link to comment Share on other sites More sharing options...
Pauly Posted March 19, 2005 Report Share Posted March 19, 2005 they wear so fast its untrue mate if i were you i would not buy em mine lasted 2 days :o Pauly Quote Link to comment Share on other sites More sharing options...
planetXstar Posted March 19, 2005 Report Share Posted March 19, 2005 Zoo_Rider said: they wear so fast its untrue mate if i were you i would not buy em mine lasted 2 days :o Pauly ← mine work fine without a grind and they dont wear too quick Quote Link to comment Share on other sites More sharing options...
trialsking 55 Posted March 19, 2005 Report Share Posted March 19, 2005 Zoo_Rider said: they wear so fast its untrue mate if i were you i would not buy em mine lasted 2 days :o Pauly ← woot! i have mine on a medium grind and ahve done for almost two months and they're like 1/5 worn down :P p.sp theyre crap in wet Quote Link to comment Share on other sites More sharing options...
Andy Vox Posted March 19, 2005 Report Share Posted March 19, 2005 Ive got em without a grind and they r great in the dry, abit of water though and u mite aswell go home. They wear resonably fast considering i have no grind. Quote Link to comment Share on other sites More sharing options...
Si-man Posted March 19, 2005 Report Share Posted March 19, 2005 Rossi has got his on the front on a ceramic rim (I think) and they lock up abit too good. Not sure what they're like in the wet, but in the dry they are very good Quote Link to comment Share on other sites More sharing options...
Da Make Posted March 19, 2005 Report Share Posted March 19, 2005 (edited) I use this stuff on my smooth Echo mod rim with ZOO! pads. It is CRC Belt spray that increases friction. I gives SUPERB modulation, grip, lock on... the best brake power solution! A can of this last forever and it is very easy to apply onto the rim. Just spray some of it to a papertowel and then spread it onto the brake surface. It lastes longer than some good quality tar/bitum. Edited March 19, 2005 by Da Make Quote Link to comment Share on other sites More sharing options...
Luke Drewery Posted March 19, 2005 Report Share Posted March 19, 2005 Da Make said: I use this stuff on my smooth Echo mod rim with ZOO! pads. It is CRC Belt spray that increases friction. I gives SUPERB modulation, grip, lock on... the best brake power solution! A can of this last forever and it is very easy to apply onto the rim. Just spray some of it to a papertowel and then spread it onto the brake surface. It lastes longer than some good quality tar/bitum. ← Yeh but whats it like when its wet? I use zoo pads on a smooth koxx rim and they bite very well, just when theyre wet that they turn crap. Im grindin soon though just to see if theyll be better. Quote Link to comment Share on other sites More sharing options...
Da Make Posted March 19, 2005 Report Share Posted March 19, 2005 scunnytrials said: Yeh but whats it like when its wet? ← "*Tacky, non-drying, water-resistant film minimizes drive belt slippage, resists water wash-off, maintains belt flexibility and prevents loads from slipping on conveyor systems." -States on the can. I live in Finland, we have still loads of snow this time and it doesn't affect to my braking at all even if I get my rim really wet. Quote Link to comment Share on other sites More sharing options...
SQuiT-man Posted March 19, 2005 Report Share Posted March 19, 2005 Wow, that stuff sounds interesting. Anyone else use it? I'm mainly interested because I do streety-type mod trials, on SMOOTH rims (i hate grinds lol). So I want modulation for manuals, etc, but I still like to do a lot of power moves so need really good biting brakes. At the moment I use tar with crap pads, it bites insanely, but has no modulation at all. So what setup would you reccomend me using on a smooth rim for modulation AND very good lock? Would you reccomend me using that spray stuff? with what pads? And how much does it cost? Cheers Quote Link to comment Share on other sites More sharing options...
Da Make Posted March 19, 2005 Report Share Posted March 19, 2005 SQuiT-man said: Would you reccomend me using that spray stuff? with what pads? And how much does it cost? Cheers ← It's about £5 or cheaper. Use some harder compond pads if good modultion is desired by sacrificing bit of lock. KOXX BLOXX will do. You only need very slight amount of this stuff. It is easily removed with either some acetone or CRC Brakecleaner. Quote Link to comment Share on other sites More sharing options...
SQuiT-man Posted March 19, 2005 Report Share Posted March 19, 2005 Thanks, so where can you get these things? Does it still keep a good lock when u need it for big stuff, no chance of brake slip, etc? Cheers Quote Link to comment Share on other sites More sharing options...
Wayne-king Posted March 19, 2005 Report Share Posted March 19, 2005 in my experience, the best pads on a grind at the moment seem to be heatsink batch B's (the clear ones) the grip is amazing! Quote Link to comment Share on other sites More sharing options...
munkee Posted March 19, 2005 Report Share Posted March 19, 2005 i ve been running them on the front and they are bloody amazing to be honest. Its quite sickening how well they have been working for me on the front. Ive wipped them on to the back to see how well they were work there. But for the front deffo amazing thats on a very very very light grind. Quote Link to comment Share on other sites More sharing options...
Da Make Posted March 19, 2005 Report Share Posted March 19, 2005 SQuiT-man said: Thanks, so where can you get these things? Does it still keep a good lock when u need it for big stuff, no chance of brake slip, etc? Cheers ← CRC pruducts are available from most good gas stations and DIY shops. KOXX BLOXX brake pads are available from your Koxx/TryAll dealer. Brakes with CRC Belt spray on the braking surface have no change of accidently slip anything. All my experiences are very positive. Just today when me and my friend were riding outside and swapped bikes for a moment my friend said: "What the heck! Your brake locks directly! So powerfull! Can you treat my rim also?" Try it! Quote Link to comment Share on other sites More sharing options...
JT! Posted March 19, 2005 Report Share Posted March 19, 2005 sammerz said: Does anyone knoe if Zoo pads work better with or without a grind? :"> ← All pads work better with a grind. The wear rate is a different matter, because the zoo pads are soft, i would only run them on a very light grind at the most. (Y) Quote Link to comment Share on other sites More sharing options...
roozor Posted March 19, 2005 Report Share Posted March 19, 2005 (edited) Zoo! pads are made for a smooth rim, i have a koxx/try-all smooth rim on my planet-x zebdi and i have had my zoo! pads about 2 weeks, their absolutely the shit! Such an amazing lock. Best pads i've used by far! I'd recommend them to anyone Also on a smooth rim the wear rate after 2 weeks, they havent worn down at all! Edited March 19, 2005 by roozor Quote Link to comment Share on other sites More sharing options...
