Upside Down 4 Bolt Mounts
Dr. Nick Riviera
can i run my 4bolt mounts upside down as shown in my paint drawing below
with the bit thats says magura underneath and the one with the flat surface facing upwards , so i can run washers instead of booster spacers and get it all closer to the frame
key
red = bit that says magura
blue =bit with flat surface
black= frame and 4 bolt mounts
yellow = washers
grey = booster
hows about experimenting and seeing if you can reduce flex by 10 minutes work
Go on then (Y)
You're only gonna find out by trying. My prediction - There's probably not enough clearance. But try it, don't just talk about it!
the 4 bolt brackets i've seen have had curved edges on the bottom brackets that fit over the mount itself. this isn't present on the top bracket. that means your bracket is not going to mate as well with the mount as it would if it were run the right way, and might actually sit higher. i mean seriously, 4 bolt boosters all have like 10 mm of spacers underneath them already. if you really think you can feel the flex (questionable to begin with), then why not design a booster that can fit around the mounting bracket and doesn't need spacers?
Edited by durkie
