Tv Card
pashley pro
hi there people ive just put a WinTv go card in my pc and its all installed the problem is the picture for the channels is fuzzy.Ive tried tracking it but no use. Its all connected to the houses tv aerial but when i wiggle the cable end round in the pc it the picture can go worse or a little better but not stay. also if i put the actual cable into my proper tv the picture is loads better. Anyone got any ideas could it need a new cable.i thought that if it works ok on the tv then i might not need a new cable.
are you using a signal booster to boost the signal from the one aerial to all the tvs round the house if you invest in a good one of these you will find picture will be perfect!!!!
