Cleaning Inside Of The Hub
holroyd-wanna-be
If its a hope then ive used GT85 and Disk Brake cleaner to clean out mine before. Just try not to flush all the grease out the bearing at the same time :turned: I use a drop of light engine oil in my hub. Doesnt really matter if you put too much in as it just ends up splatted all over the drive side flange :)
