psycho Posted March 9, 2005 Report Share Posted March 9, 2005 Hi guys, just ripped a tube out while out today.i have replaced tubes before using the good old two blocks of nylon and a hammer that comes with the magura service kit but as im at uni i dont have access to a vice just wondered if anyone knows a way to replace the metal screw into the tube, without using a vice. ive tried using hot water to soften the tube without success. i took it to my b*****d LBS and they said they wouldnt do it because they are not qualified magura technitions. thanks a lot chris Quote Link to comment Share on other sites More sharing options...
bluecatracingcat Posted March 9, 2005 Report Share Posted March 9, 2005 Hi guys, just ripped a tube out while out today.i have replaced tubes before using the good old two blocks of nylon and a hammer that comes with the magura service kit but as im at uni i dont have access to a vice just wondered if anyone knows a way to replace the metal screw into the tube, without using a vice. ive tried using hot water to soften the tube without success. i took it to my b*****d LBS and they said they wouldnt do it because they are not qualified magura technitions. thanks a lot chris ← Sounds like they aren't even qualified to sell bikes. As you've done in the past it isn't hard with a vice. I've used home made wooden block when I didn't have proper ones. AS for the vice... you need leverage... go to you're least fav door and open it, then hold the hose/block thingies in the hinge side passing the hose through from other side. Then bash with big rock or a hammer. Haven't tried this but I will next week when I have to make up hoses for my girlfriend bike. I'll see if I can do it! :turned: Quote Link to comment Share on other sites More sharing options...
munkee Posted March 9, 2005 Report Share Posted March 9, 2005 ask the lbs if you can do it then.. pay them.. just get it done. Try the door thing also it may work Quote Link to comment Share on other sites More sharing options...
