Help With Rear Dropouts Please.
Will Arnold
i need some info about rear disk tabs.
can somebody please tell me the distance between the holes of a disk mount and also the distance they need to be away from the axle centre.
i also need to know the angle of the disk holes relative to the axle.
cheers.
Will
Edited by WILL ARNOLD
  div said:
I would think that it has to be at a set distance and at a set angle relative to the axle, it can be anywhere on the radius, but must be at the correct angle.
yer, thats the angle in looking for :)
i've found out that the distance between tabs is 51mm. still need to find the angle :turned:
Cheers :-
Will
