Networking 2 Comps Together
cant_ride
Look at the coloured cables at each end of the network cable. If theyre in a different order, its crossover and will work :blink: . If theyre exactly the same you need to go buy a new cable.
Then just plug em in and set it up software-wise.
Well i didn't recommend that this guy does that, but that is a viable solution to connect computers together..
Also if for any reason you wanted to connect more than two computers together, you could use a hub, whereas you couldn't use a single crossover cable...
:blink:
:blink:
but then he can buy a hub/switch later if he needs which I doubt he will as he a student :angry:
pinky
