Motorcross Madness 2
If it's on your PC, go into the Motocross Madness folder, and open the .pdf manual which has a list of all the standard tricks. However, you can do other tricks which aren't written there. Basically, you can do stuff like no-handed supermen, etc., just by - for example - doing a superman, holding down the lean-back button and pressing backwards when you release the trick key.
And so on :angry:
There are loads of tricks though, it's all good :blink: Every lean forward and every lean back + every trick 1 and trick 2 key + every direction (up, up-right, right, down-right, etc.) has a different trick, so there are shitloads there.
